mlh's avatar
mlh
Very Expensive Preventative Maintenance
For anyone that will be replacing the drive belt on a Ford V-10 anytime soon: If you happen to remove all the plastic trim and air filter housing, etc., please be aware of how you put it back together. I recently took a trip and when I got on the highway, I hardly had any power. I could barely get to 60 and could not muster up enough speed or acceleration to pass anyone. I would slow down considerably on overpasses. I unhooked the Jeep to see if it improved. It didn't. I figured it must have been the fuel filter. I stopped at the nearest Auto Zone and they sold me a fuel filter for a 2010 E 450. I get out in the parking lot and could not find it. I checked the manual and it said that the filter was located in the tank. I guess the guys at Auto Zone didn't know that. I went back inside and returned it. Got it home and ordered a new fuel pump assembly since you can't order just the filter. Dropped the tank, replaced the assembly and back together. This was not an easy task by the way. I let it get down to a quarter tank. I can't imagine if it had been full. Anyway, I took it on a test run. It seemed better, but not much. I got out on the highway and things did not improve. I pulled over to disconnect the battery to see if resetting the computer would help. While the battery was disconnected, I decided to check the air filter just in case although I had recently replaced it. I removed the first section of the housing. When I went to put it back on, it would not go on quite right. There was a flap that was positioned the wrong way almost blocking the entire intake. I corrected the flap, reassembled everything and got back on the road. It ran perfect. Oh well. At least I have a new fuel pump that should last me for quite a while now.
  • j-d's avatar
    j-d
    Explorer II
    ^^^JAXFL - Not ignoring you. Your PM didn't reach me, and I didn't hear back from the one I sent you...
    Back to Topic, OP thought it was time to change it. Preventive maintenance.
    My definitive post on E-Series Fuel Filter Change
  • j-d
    just sent you another... the first one came back strange... said don't call me J-D.
    Anyway just sent it to you.
  • JAXFL wrote:
    Why did you do this in the first place? Was it broken or what?
    I change belts after a few years regardless. I'd rather change it my driveway than the side of the road.
  • mlh-
    When you come to Florida stop by and change mine... it is 2 years older than yours.
    Thanks
  • I also had a similar problem and the pump was changed out without any effect. I did learn however that my rig had four fuel filters. One for the in-tank pump, two canister types after the regulator and one in the carb. All had been changes with no help.
    Turned out it was the P30, oil pressure relay and not the fuel system it's self.
    You're right, very expensive.
