ahling's avatar
ahling
VIN location
I purchased a 2006 Coachman Sportscoach 372ds and I need to take it to DMV for registration. They will need to visibly see the VIN number. Can anyone guide me on where to look cause I'm lost
    Have you found it yet?
    Did you buy it in California or from another state?
  • On our Winnebago, there is also a chassis VIN sticker in the entrance door.
  • JaxDad's avatar
    JaxDad
    Explorer III
    fishingbob61 wrote:
    Is it a C or A If it is a class C it is on driver side inside the windshield and inside the drivers door, if it is a class A should be on the wall behind driver on the fed. spec sheet.
    Considering with most coaches the name at least hints at the size and such, a 2006 Coachman Sportscoach 372d would seem to indicate that it's 37' feet long and diesel. Google seems to agree.
    It's likely then on a tag clearly visible in the engine bay.
  • there must be one visible through the drivers side window.
    The VIN will probably be for a 2005 chassis
  • Is it a C or A If it is a class C it is on driver side inside the windshield and inside the drivers door, if it is a class A should be on the wall behind driver on the fed. spec sheet.
    it's on the title...that ain't good enough? anyway, if you have a driver's door look there.
