bjbear
Jun 08, 2018Explorer
VMSpc Help
I have installed a VMSpc system running on an HP laptop. Everything works great with the exception of the Histogram. All the lines/traces just stay on the bottom and show no movement, even though ...
All the lines/traces just stay on the bottom and show no movement, even though a normal gauge shows that there is a value. Anyone run into this?? And have a solution?
Also, I have been trying to register on the Silverleaf forum for a while, but the Captcha does not work so I can't register.
Are you using the latest version v4.0.8?
If not, maybe the newer version will fix your problem?
