- sjholtExplorerAlso- Lube that O ring and the threads the can spins on to.
- hostageExplorer
SidecarFlip wrote:
hostage wrote:
SidecarFlip wrote:
The more the system is used (pressurized and heated, because compressed air is hotter than ambient, the longer the change frequency is). Ocassional use (like a Motorhome) decreases the change interval. Reason being is, when the system drops to no pressure, the entrained water vapor condenses in the lines and when the system is pressureized again, that condensed water vapor winds up in the cartridge... Pretty simple really.
got a filter coming its only $38 all in so no big deal
change it and good for another 9 years (last one lasted that long)
When you change it (if the new one don't come with the 'o' ring. Make sure the 'o' ring seal is seated in the housing correctly.
You'll know when you remove the old one if 9 years is feasible or if it was saturated a while ago.
will do thanks;; the picture shows a new o-ring - DSDP_DonExplorerWow.....you have quite an attitude! You came here questioning if you should change a ten year old filter that has a recommended interval of three years, just to save $39.00. Then you have an attitude about the helpful responses. :S
- SidecarFlipExplorer III
You'll know when you remove the old one if 9 years is feasible or if it was saturated a while ago. - hostageExplorer
kdk wrote:
Amazon has them for $39, so why take a chance on damaging some thing way more expensive.
I had previously posted already that I bought one for $38 ?? - kdkExplorerAmazon has them for $39, so why take a chance on damaging some thing way more expensive.
- hostageExplorer
change it and good for another 9 years (last one lasted that long) - SidecarFlipExplorer IIIThe more the system is used (pressurized and heated, because compressed air is hotter than ambient, the longer the change frequency is). Ocassional use (like a Motorhome) decreases the change interval. Reason being is, when the system drops to no pressure, the entrained water vapor condenses in the lines and when the system is pressureized again, that condensed water vapor winds up in the cartridge... Pretty simple really.
- ct1964upsExplorer
hostage wrote:
Just found this by Bendix;;
air dryer cartridge should be replaced every year or 100,000 miles.
For pick up and delivery operations, or for double- and triple-trailer line haul trucks, every two years or 200,000 miles is recommended.
Line haul operations using a single trailer should swap the filter out every three years or 300,000 miles.
so the more use,less you have to change it...motorhome use looks as if it should be changed yearly...I do 17k a year and change every other year - hostageExplorerJust found this by Bendix;;
