FirstSmurfExplorerSep 25, 2018Wall PaperHello, I have an 2008 Itasca 39W, GAs, and I am having problems with the wall paper sagging. is there a cure or a way to prevent this from happening?thank you
2 RepliesReplies sorted by NewestppineExplorer IIISep 26, 2018Remove it. Use a steamer.donn0128Explorer IISep 25, 2018The glue has let loose for some reason. First thing I would do is proove there are no leaks. Then, using a hypodermic needle inject glue and using pressure hold it in place for a day or so.
Related ContentBest Paper California map!Pimples in wall paperwrinkled wall paper?RV toilet paperMatching up contact paper / wall paper
