emzee's avatar
emzee
wrinkled wall paper?
Just wondering if anyone had a solution for wrinkled wall paper. It's wrinkled around the edges of the door hardware. I was thinking of getting it moist and trying to smooth it that way?
  • We're going to try the heat method thanks!
  • The factory told me they use a heat gun to heat it and smooth it out. I think it actually shrinks a little. I fixed a small spot with DW hair dryer. Worked great l
  • GENECOP, you are right, didn't work. I think it needs heat to do any moving. Maybe better leaving it alone.
  • That will not really work. Wrinkles are caused by improper install, very difficult to just smooth out. If it is large enough cutting or slicing and flattening could work...
