j-d wrote:
Hank, What are your:
Axle Weights
Tire Pressures
Coach Length and Wheelbase
Aspect Model Number
Alignment Numbers esp. Caster and Toe
And:
Any chassis/steering upgrades so far?
Are you towing a Vehicle or Trailer?
Alignment-Wise: On the E-Series, Road Wander is a result of too little Caster and not too much. Mid-range spec for E is around +3 and we're finding +5 tracks much better. The F-Series must be different because if an E went less than +3 let alone negative you'd have to tow it or park it.
j-d, +5 degrees sounds crazy to me. They must really have those Fords loaded heavy over the front axle to cause you to put that much caster in one.
