goufgators's avatar
goufgators
Yes, another 'wandering' rant...er ... post...
Probably the most discussed topic on this forum and likely others is that of the notorious steering wander on Ford F-53 chassis’. Judging from the number of requests for advice on remedying the problem, it seems to be close to a universal problem. My 2017 Winnebago, Sunstar with less than 4K miles is not an exception. Why I did not recognize this problem when test driving it is a mystery. I was probably too engrossed with gadgetry in the coach such as a flat screen that comes up out a counter area, electric sun shade that coves the windshield, bed that comes down over the front seats, air mattress in sofa and other items that are mostly to guarantee a sale…well, you get the idea. I have done practically everything that has been recommended on this Forum such as: Front-end alignment, weighing the coach then airing up in accordance with Goodyear’s PSI chart, installed steering stabilizer, installed rear trac bar and had caster adjusted to (I believe) 6 or 7 degrees positive. Thinking about next having toe in adjusted to Ford’s max 3/32. All of these things have been recommended by, I believe, well meaning members of this forum and there has been a bit of improvement but remains a difficult, tiring drive. I’m thinking now about having a Steer Safe installed but wondering can one be installed when there is already a steering stabilizer? Also, I’m still open to suggestions (actually pleading for) …maybe something you did to correct this problem on your coach short of trading it in for a diesel pusher (admittedly, I’ve given that some fleeting thoughts) ?.
