I have finally found an online reference describing the front end dynamics of a rolling vehicle where weight and tire inflation pressures in effect change the caster trail dynamically. Right or wrong, here it is:
Caster Trail or TrailingStart Quote:
The steering axis (the red dotted line in the diagram above) does not have to pass through the center of the wheel, so the caster can be set independently of the mechanical trail, which is the distance between where the steering axis hits the ground, in side view, and the point directly below the axle. The interaction between caster angle and trail is complex, but roughly speaking they both aid steering, caster tends to add damping, while trail adds 'feel', and returnability. In the extreme case of the shopping trolley wheel, the system is undamped but stable, as the wheel oscillates around the 'correct' path. The shopping trolley/cart setup has a great deal of trail, but no caster. Complicating this still further is that the lateral forces at the tire do not act at the center of the contact patch, but at a distance behind the nominal contact patch. This distance is called the pneumatic trail and varies with speed, load, steer angle, surface, tire type, tire pressure and time. A good starting point for this is 30 mm behind the nominal contact patch.
End Quote.
