I started this post several months ago. The comments and suggestions have been extremely helpful. Thanks!
This is an update of what I did and the tangible results of each modification.
- Adding the Safe-T Plus had virtually no effect on the stability.
- Adding the front and rear sway bars also resulted in little or no improvement.
- At this point, the only positive results came from realigning the front end.
Attached is the alignment specs before and after. The question I have relates to the caster on the front left. All the suggestions were for at least a +5. However, the mechanic said he could only get a +4.7. Would attempting to realign for a +5 or more be worth the time and cost?
