Daveinet
Dec 30, 2014Explorer
There is a simple solution. IF you are backing straight up, lock the steering wheel. That will keep the wheel straight and prevent it from slamming one way or the other. The other solution is to put the motorhome in neutral, start the car and pull the motorhome back with the car. Second method is only advised if you are on flat hard ground. Don't try to pull the motorhome on soft dirt or up a hill. You should be able to roll the motorhome without stepping on the gas, but just idling backwards.
38,768 PostsLatest Activity: Nov 21, 2015
