SKIPCAROL's avatar
SKIPCAROL
water filter and pressure regulater
We are at a campground with high water pressure and use a regulator
(we always do)and a filter. By the time it gets to the tap, pressure is really low...if I take the filter off it's ok. Do you think the filter (it's new) somehow slows the flow even more?
  • Is the pressure just as bad with water pump only. Mine did this, an A Change of filter did the trick.
  • I just got my new filter cartridges that I ordered online. This is the replacement element for the under the counter water filter. This is a 3M filter element so it is not some cheap Chinese knock-off. On the enclosed paperwork, that I usually throw away, it states that the service flow rate of the filter is 1.5 GPM with an input pressure of 25-125 PSI.
    My water pump has a flow rate of 5.5 GPM which is one reason why the flow rate for the kitchen faucet is less than that at the other faucets.
