- luvlabsExplorerThose are known as water softners - same thing used in your house but scaled down to use in your motorhome. RVWaterFilter Store is a good source.
These are not filters, btw. They use a an ion exchange resin to remove calcium. You regernerate the resin with plain old table salt. They are availalbe in variouse sizes depending on how much water you use. - Executive45Explorer IIIJust read the label...WalMart, Home Depot, Lowes....they all have them..some remove calcium, some remove chlorine, some enhance taste...the label will tell you which does what......Dennis
- Maw__Jim___JakeExplorerThanks for the info, I'll check it out.
JMaT - dons2346ExplorerYes, they are available. You can find them here https://www.rvwaterfilterstore.com/DWReplaceableCartridge.htm
- Sully2ExplorerEverPure does I believe
38,749 PostsLatest Activity: Nov 26, 2019
