- pkunkExplorer
rolling_rhoda wrote:
In our Coachmen Sportscoach we had great acces to the water heater and valves from inside, by removing a dresser drawer in the bedroom.
Look there - rolling_rhodaExplorerIn our Coachmen Sportscoach we had great acces to the water heater and valves from inside, by removing a dresser drawer in the bedroom.
- Old-BiscuitExplorer IIIStatement from owners manual:
Turn the water heater bypass valve to the bypass position. (This valve is located near the water heater incoming lines at the rear of the water heater. The water heater is usually located in a base cabinet in the kitchen, and it may be necessary to remove an access panel to reach the bypass valve.) - rvman53ExplorerOk....thanks
- 1492ModeratorMoved from Forum Technical Support
- pulsarExplorerOn a friend's 2014 Coachmen, I found the bypass valve on the input line on the back of the water heater. I had to remove an access panel.
One would think that the owner's manual would tell you were it is. My friend didn't have an owner's manual!. He said there wasn't one in the info kit.
Tom
38,736 PostsLatest Activity: Jan 14, 2015
