martolina
May 13, 2014Explorer
Water heater will not restart
I have an atwood 6 gallon water heater in my motor home that has the electronic start from inside the coach. It will start fine and will heat the first tank to "completion" and then when it is time to heat new water or reheat the water in the tank that has dropped below desired temperature, it will not re-ignite. I have done all the burner "blow-outs" and checked for bad connections. Any suggestions on what part is bad?
Thanks!
Thanks!
