zach477's avatar
zach477
Water Intrusion In Bedroom Slide!
I have a 08 Fleetwood Fiesta bunkhouse, and I have been finding a wet spot underneath the mattress of the lower bunk. It's in the back corner of the floor. In the really terrible diagram below (top down view), the front of the RV is to the left, and the * marks the wet spot. The fridge and water heater are just to the left of the star, but they aren't part of the slide so I can't see how a leak or condensation from them could be causing this.
_______|*-----------|
_______________|
I first noticed it a few days ago when I was cleaning/organizing for a trip. I had been parked with the slides our for a few weeks. I used towels and a space heater to completely dry it up before hitting the road for a few days. We drove a bout 1200 miles round trip and kept the slides in the when we parked. We also hit very little rain. If it rained at all, it was just a light misting for a few minutes.
Now that I'm back home, I checked again, and the area is moist again. This seems weird since we didn't really have any rain. My suspicion is that the window isn't sealed properly and water worked its way down inside the wall and then to the floor, and after I dried the floor there was still enough moisture in the wall to work its way down and make the floor wet again.
Any other thoughts? The slide and slide topper appear to be in great shape from the outside. I'm kind of freaking out about it being that there could already be expensive water damage. :(
Zach
  • MountainAir05 wrote:
    any water line, ice maker, hot water tank. Water moves to the low spot. You you have a sink in the slide. Check the drain line also if you have one in slide.
    We have a kitchen slide so water and drain. Both have leaked.
    There aren't any water lines in the slide. The fridge, sink, and water heater are all to to the left of the slide. The bathroom is across the "hallway". The slide only consists of the bunk beds, and the actual bed.
  • any water line, ice maker, hot water tank. Water moves to the low spot. You you have a sink in the slide. Check the drain line also if you have one in slide.
