Gjac
Jun 04, 2013Explorer III
popeye766 wrote:Sounds like the difference between what you did and what Fire Up did is your mister system will probably cool the air going into the A/C condenser then into the radiator vs water cooling more directly the radiator if I understand both of your posts correctly.
You need a mister or sprinkler about 6-10" in front of the AC core so it will spray on it and the fan will suck it to the rad. core...you want to hit as much center rad core as possible and other coolers there if you have them. Cooling the tank is not as efficient as your rad core.
38,780 PostsLatest Activity: Aug 05, 2026
