Gjac
Jun 06, 2013Explorer III
popeye766 wrote:I ran 2 4 in ducts as you described when I first bought the MH and had the leaking exhaust gaskets replaced what I found was that the following year the exhaust manifolds were cracked between the ports(not leaking)from rain water getting in hitting the hot manifolds. My scoops were lower under the grill so be careful. Headers and other mods helped remove a lot of the heat from the dog house and added way more power.
Iam determined to evacuate the hot air from my Pace Arrow eng compartment....not only does it produce tremendous heat but I believe it is trapped there....I have cut two holes above my headlights and ducted 4" ducts of fresh air right on top of my manifolds...next Iam going to remove the mud flaps in front of the front tires cause I believe these are the main air block of the fresh air to to the eng....
38,780 PostsLatest Activity: Aug 05, 2026
