RV_Hero
Jun 26, 2019Explorer
Water leak inside RV from HVAC running
I discovered a cheap and fast solution.
I have a Winnebago 2009 RV, Since I have owned it I have always had a leak inside on humid days and ac running. Service calls have not solved it.
I finally researched and investigated and did it myself. Problem was manufacturers installation. They installed the roof unit tight to the roof. so tight it plugs the drain holes, Solution is simple plastic wedge installed from outside both sides to lift HVAC of roof so drain holes will both work free for condensate water, my pan is dry as a bone now. I also have pictures, How can I post this?
