w4phj
Sep 04, 2013Explorer
I have the identical coach and had the identical problem. First my water pump relay was damaged by the water leak. The water pump relay is mounted next to the light fixture. I installed a new relay inside a ZipLock bag. The leak source turned out to be a loose W/D fitting clamp at one of the hose bibs. Hope you find the same leak source when you remove the bottom closet shelf in the toilet cabinet.
