the_vfox
Jun 28, 2015Explorer
fenwickfam wrote:
Found it!!! :D
We took the panel off for the water heater and sure enough, a hose had come off! One good thing about a workhorse chassis, they are high enough to crawl under easily!
Thank you all for your help :)
You are so appreciated!!
Glad you found it. If you have not thought about it, you should check and tighten all your hose connections. As a safety feature until you do, i would suggest your water pump stay off when you are not in the coach. Also, while you are away, turn the city water off when you are connected to it. After you have checked all your hose connections, you will have more confidence in your system.
