garmpExplorer IIOct 26, 2022Water pressure regulatorDo you use/recommend a water pressure regulator when connected to city water? If so with or with out a gauge?
2112Explorer IIOct 27, 2022As mentioned, the cheap tubes restrict flow and only get worse with time.I've been using This One for about 6 months and it's much better. I adjusted it to 40psi
Related ContentWater Pressure Regulatorwater pressure regulatorswater pressure regulatorsWater pressure regulator...Water pressure regulator
