Jim
Mar 19, 2018Explorer
ct78barnes wrote:
The other day I was just finished my shower and it worked fine worked fine , Then went to run the water and the pump was off. Turned it back on and a few hr I tried it again and it was off. It still works fine but this is new. My coach is 7 years old. Maybe a ground wire or a switch , I have never herd of this problem but thought I would see if any body has had this problems and what they found out.
Something similar happened to mine once. It would toggle between Off/On and On/Off seemingly randomly. I never did figure out what caused it but it went away as soon as I pulled the wires off the control module (inside the wet bay very near the pump) and cleaned the contacts.
Can't help other than that because they are very reliable and don't go bad very often so not much expirience.
Has there been rain where you are? I'm wondering if you got a drop of water or two on the control contacts or on the contacts of one of the switches? Check the basement pump switch first, if you have one.
38,766 PostsLatest Activity: Jan 10, 2026
