im trying to replace a shurflo 5900-0201 5.7 water pump with something similiar shurflo recommends the 4048 4.0 wich is much smaller.i replaced it with a aquajet 55 5.3 wich is noisy and has a low hum...
The SHurflo 4048 is recommended as 'direct replacement' for the Shurflo 5.7 Variable Speed pump
It is rated for 4 gpm at 55 psi It has an internal bypass valve to control low flow shutter (allows pump to run continuously during low flow demands vs stop/start/stop/start action)
