Greetings, On my 1995 Tioga, my water pump stopped pumping water. I can hear the motor running, but no water from the faucets. I have cleaned out the filter, and don't seem to have any leaks anywhere...
I had similar issue last year with mine--- the pump ran but did not build pressure; after checking all the lines for clogs/leaks I called the repair shop- the diagnosis: pump went bad. Easy fix and approximately $100. No problems since. Good luck---
