I am going out to my lease this weekend where the camper is, and I was needing some more troubleshooting tips. What I have done; no crack in filter housing, plenty of water in tank,(at least it is over the outlet fitting), replaced the tubing from the tank fitting to the fitting near the filter,cleaned out both aerators and filter. I would like to run some sort of test to see if the pump is working,could I disconnect the waterinlet tubing and turn on the motor and put my hand over the pipe going to the filter to see if there is any suction?Will this work? Also, if no luck there, I think I will replace all the fittings on the tank side if the pump.Any other suggestions?
Thanks,
Jim
