My water in the rv keeps running when I turn off the water. I have to turn off the switch to stop the pump. No water is leaking out from anywhere so I do not have a leak? Any ideas what might be the p...
the check valve at the pump is leaking and pressure in the system is pushing water back into the fresh water tank. Might be able to clean it out or even replace it.
