camp104ExplorerJun 13, 2018Water pumpMy water in the rv keeps running when I turn off the water. I have to turn off the switch to stop the pump. No water is leaking out from anywhere so I do not have a leak? Any ideas what might be the p...Show More
MrWizardModeratorJun 13, 2018what switch ?water pump switch ? battery disconnect ?water won't stop ?, do you mean close the faucet, but water keeps runningreplace faucetare you hooked up to city water ?water pressure might be to high and you need an inline regulator
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
