camp104ExplorerJun 13, 2018Water pumpMy water in the rv keeps running when I turn off the water. I have to turn off the switch to stop the pump. No water is leaking out from anywhere so I do not have a leak? Any ideas what might be the p...Show More
Ralph_CramdenExplorer IIJun 14, 2018If the pump is a Sureflo it may be as simple as the pressure switch setting needs adjusted. A small allen head screw on the front end of the pump.
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
