camp104ExplorerJun 13, 2018Water pumpMy water in the rv keeps running when I turn off the water. I have to turn off the switch to stop the pump. No water is leaking out from anywhere so I do not have a leak? Any ideas what might be the p...Show More
D_E_BishopExplorerJun 14, 2018My pump would cycle on and off, for a quick fix while on thr road, I put a check valve on the discharre side of pump.It took care of the sympton of a bad check valve in the pump head.To solve thr problem, I removed the pump and took the head apart and cleaned all parts of the head, sealed with a little silicone. Working fine again.
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
