myface
Jan 26, 2020Explorer
Water pump
I had strange problem and finally fixed. Last night all was working fine, but when I woke up, I had no water. I went crazy looking at all fuses and panel, but still no power to water pump. Finally, I ...
4x4van wrote:dougrainer wrote:Wrong. My Itasca has 2 water pump switches, no controller. It is wired just like 3-way light switches in a house. I can turn the pump on or off, from either location. If both switches are up, the pump is on. If both switches are down, the pump is on. If they do not match (i.e. one switch is up, the other switch is down), then the pump is off.cavie wrote:
You might have got it working but you have not fixed the problem. You should be able to turn the pump on and off from both locations.
If you do not have a pump controller and just 2 or 3 water Pump switches, then if ONE is ON, then you cannot turn the pump OFF from the other switches. Doug
