str8shooter_mn's avatar
Jun 20, 2023
Water pump
Pulled into RV park and all three took a shower. Pump worked fine. Later, noticed light was out for switch. No voltage to pump when switching switch. Fuse panel on lower foot of bed frame, all fuses good. Checked breakers. Ok.any other suggestions appreciated. Pump was replaced 2 years ago with better pump. No problem trouble shooting the old one
  • Take your voltage meter (if you do not have go get one) and see if you are getting voltage at switch. If you are getting voltage at switch, there may be a in line fuse at the water pump location.
    Good Luck
  • Do you have a multimeter or 12 volt test light that you can use? I would test if the pump is even getting power. My guess though is the switch went bad so you'll want to check there too.
