revump's avatar
revump
Water Pump
I have an 06 See Ya. When the fresh water is full, my pump works fine. When it get down to two buttons, it is intermittent. ?????
  • Ron8877 wrote:
    Where does the water come out of the tank? If there is a pickup line that goes from the top down then it may have a crack in it and not staying in the water that is in the tank. On our mh the pump gets its water from th bottom of the tank so as long as there is water in the tank we are fine.
    Ron
    Same here and I did take it apart a while back as it was acting up a little. Cleaned everything inside, applied silicon grease to the gaskets and evenly tightened all the screws. Also have it mounted with just one screw and a folded cloth (sponge might be better) under it. Works great now and sounds a lot better too, without the line hammering so much.
  • Where does the water come out of the tank? If there is a pickup line that goes from the top down then it may have a crack in it and not staying in the water that is in the tank. On our mh the pump gets its water from th bottom of the tank so as long as there is water in the tank we are fine.
    Ron
