chuckftboy
Apr 25, 2018Explorer
The bowl you describe sounds like the strainer bowl. If it broke off the pump, you would be sucking air and that would be why your faucet sputters. Did you find a screen in that bay also?
If you can't drain your tank, you probably have a valve up stream closed. Kind of like when you put a straw in a drink and put your finger on the open end. When you lift the straw, liquid won't come out until you remove your finger.
38,763 PostsLatest Activity: Dec 26, 2025
