dengineerExplorerSep 08, 2013Water softener...Does it matter wether the softener is connected before the whole house filters or after? Any comments will be greatly appr.!!!! Thank you!!!!!! Tony
BrianinMichiganExplorerSep 09, 2013On almost any setup that I have seen the filer is before the softener because it catches grit before it goes into the softener. That way it doesn't wear and grind the moving parts of the softner
