Doc_Eagle's avatar
Doc_Eagle
Water storage tank low point drain
Wondered if anyone might know the location of the low point drain on a 1993 Fleetwood Flair 22D. I spend several hours crawling under, looking in cabinets, under the plywood over the tank, etc, but was unable to find it. Please help, thanks in advance.
  • Thanks for all the help. FOUND it under the bed, behind the water pump and under the heat duct work. Found it wasn't as empty as I thought, about twenty gallons left. Thanks bunches.
  • On the Pursuit, mine are on the floor under the bed, just above the water pump.
  • Thanks, gave me some good places to look. I am guessing it would have to have one right. Luckily right now the tank is almost empty but will need to disinfect it before we use it again. Happy trails you'll!
  • We have a Fleetwood Bounder. The water tank drain is at the end of the tank inside an outside compartment. The low point drains for the water lines are on the opposite side of the coach near the water pump.
  • my 1994 flair 25 footer had the water tank under the bed and there was a valve there to dump it. but it was obvious so evidently yours is hidden away some place.
    bumpy
  • My parents hada Flair of that vintage-I'll ask but am thinking that it may be just a screw plug protruding from the bottom of the coach?
  • Look under the rv. Many are operated from underneith and there should be one for cold side and one for hot.
  • Mine is at the outside shower hook-up in the wet bay,,, which is below the water heater. This is not on a Fleetwood though.
