11BExplorerSep 15, 2014Water Tank FillingHere's the problem, if I'm hooked to city water with the water tank empty I'm fine. If I fill the fresh water tank even half full and don't turn on the pump at any time after about a day the fresh wat...Show More
Old-BiscuitExplorer IIISep 15, 2014Level in fresh water tank has no bearing on why it is filling.Sounds like you have a 'fill' valveFill valve is leaking thru either because it isn't getting completely closed after using or valve is defective
Related ContentWater tank won't fillWater tank filling modNo flow from hot water tank Nautilus P1 systemGrey Tank Fillingfilling fresh water tank
