11BExplorerSep 15, 2014Water Tank FillingHere's the problem, if I'm hooked to city water with the water tank empty I'm fine. If I fill the fresh water tank even half full and don't turn on the pump at any time after about a day the fresh wat...Show More
jswatExplorerSep 17, 2014I had a similar problem with mine. After having the valve that shifts from city water to fill replaced, my problem was solved.
Related ContentWater tank won't fillWater tank filling modNo flow from hot water tank Nautilus P1 systemGrey Tank Fillingfilling fresh water tank
