BTPO1 wrote:
Being a 2015 pump, it seems strange that the pump would be bad. Are you sure it is valved properly? Is there water in the fresh water tank? Do you have an air leak on the suction side? Is the suction strainer plugged with debris? Just some thoughts on the subject, hope that they might help. JMO
No, it is the pump. The design is to blame. If you set the valves for the water system to use water from the pedestal, the pumps can be running all day long, and I think that it what happened.\
Thanks for the reply!
