RVA_Jeff
Sep 14, 2014Explorer
Waterworks Utility Panel
As with many others on here, I have a Water Works panel on my 2006 Freelander and have no idea how to operate it. I have attached an image, but it doesn't look like it's going to work, so let me ask the question I have assuming you cant see it.
There are two dials which can be up left or right
First thing says Pump/City Pressure, with both dials pointed up.
Second says Tank Fill with Left Dial Up and Right Dial pointing left.
Third is for Winterizing which has First Dial Right, Second Dial Up.
I'm looking for someone to validate a couple of assumptions:
1. Seems like most of the time, normal position whether you are using city water or using water from your tank is for both dials to be pointed up.
2. Only time you should NOT have them both up is when either filling or winterizing.
When I took delivery of this from the dealer, they had it in the tank fill position. I don't know whether this is because they literally filled the tank and didn't switch it back or what, but I'm assuming it shouldn't stay in that position now.
If anyone has any advice to provide, I'm all ears! Thanks for your time.
(Oh by the way, can you see the picture? Just curious for future posts)
