psalm10720 wrote:
I appreciate the feedback. I like the natural looking results of Maguier's 45. I might try a small portion with the floor wax stuff. I am very pleased with the cleaning ability of Krud Kutter. I wore gloves and used a sponge and sprayed on a dry surface, let it sit for a couple of minutes then wiped with a sponge and then rinsed with a hose. I've been getting a bunch of compliments from fellow full-timers. I would like to try a buffer on the second coat of polish.. A friend of mine who I trust mentioned the reason they call it floor wax is because it's for floors. If you haven't tried Maguier's 45 give it a try..
Maguier 45 is a great product. Since you have already removed all of the oxidation and have had good results with the products designed for exterior painted surfaces, I'd suggest that you stick with the waxes and polishes designed for that purpose. All of them have UV protection which is what you need to extend the life of your exterior surface. As mentioned, the floor coating is designed for interior floor surfaces. Why would you risk using it on your coach now that you have already gotten good results with the right products? Post some pictures if you get a chance.
