- rgatijnet1Explorer III
twins89 wrote:
rgatijnet1 wrote:
Prior to waxing the coach, use a fine clay bar with soap to wash the surfaces. This will give you a glass smooth surface that will take the wax better.
What is a clay bar>?
Clay bars are available at any auto supply store that sells waxes. It is basically like what it sounds like. It is a bar of clay that will remove any surface contaminants when rubbed over a wet surface.
Here is a link: All about clay bars - twins89Explorer
What is a clay bar>? - eubankExplorerI should add, by the way, that I also use Johnson's paste wax on all surfaces that absorb / lose liquid and become dried out after a period. It also seems to work pretty well in bringing some color back to dried decals, but wash them first and, as needed, use some polishing compound to remove the thin, discolored surface.
Lynn - rgatijnet1Explorer IIIPrior to waxing the coach, use a fine clay bar with soap to wash the surfaces. This will give you a glass smooth surface that will take the wax better.
- eubankExplorerIt looks pretty good. For myself, I use Meguiar's marine wax. Also kind of pricy, but goes on nicely and is fine for decal-type stripes.
Lynn
38,773 PostsLatest Activity: Apr 24, 2026
