loggenrock
Mar 21, 2017Explorer
We have a Coachmen B+ - have used an Adco cover on it past 2 winters without a problem. Key to putting it on is how you take it OFF the previous time! I've found I fold the sides up first, so it is "inside out", if you will, on the roof of the coach. Then roll it, starting from the front. To deploy, just set rolled cover on the roof, unroll over the front, drop the sides down and secure. I can do it alone, either just using the attached roof ladder, or a separate 10' step ladder. For my 25' coach the weight really isn't too bad to handle. And yes, mine has 3 vertical zippers on the curb side, so I can access the front cab door, the side coach door, or even the rear side compartment. As stated earlier, you cannot deploy the slide with the cover on. As far as the A/C, skylights/vents on the roof - it just lays right over them all winter. So far it has done a nice job keeping the rig clean. ST
