opnspaces's avatar
opnspaces
Navigator III
Mar 12, 2020
Propane leaks during storage.
Is it normal to have to bleed air from the system when you get your rig out of storage? I do shut the propane off when I drop the trailer off for storage. And I always considered it normal to have to bleed the air out to get ready for a trip. But lately I've been wondering if this is normal, or if I have a leak. So I figured I would see what your experiences are.
Do you (you personally not you hypothetically) have to bleed air out of your system if you shut the propane off for an extended period of time?
Oh as far as normal. I realize that by design there should be no leaks during storage unless you open the system somehow. But with how cheaply these components are made I would consider it normal if the majority of you also have to bleed the air out every time.
