dougrainer
Mar 13, 2020Nomad
red31 wrote:
Time + thermal cycling w/leaks causes vacuum to suck in air.
the longer closed and not used yields more air.
Yes, but HOW MUCH VACUUM needs to be generated to PULL the outside air IN thru Rubber gaskets/seals? I doubt atmospheric Vacuum can pull air in thru a tight almost completely sealed system. Doug
Having RV issues? Connect with others who have been in your shoes.24,260 PostsLatest Activity: Jun 02, 2025
