- fprestoExplorerI don't know what system you have but the following is from the HWH FAQs:
54. Can I store my coach with my jacks extended?
Yes, this will not hurt the system.
55. How long can I leave my coach parked with the jacks extended?
As long as you want. We recommend operating the system occasionally if possible.
56. Do I need to do any maintenance on the jacks or slide-outs while the vehicle is parked with the jacks and slide-outs extended?
There is no necessary maintenance for the jacks or slide-outs while the vehicle is parked. If desired, WD-40® can be used on the jack rods right before storing the jacks if dirt has collected on the rods. Refer to the following link for jack maintenance information ml47149.pdf.
57. If I’m parked for a month or two, should I occasionally operate my system?
Yes, it is good to operate the system occasionally but it is not required. - dons2346Explorer
beemerphile1 wrote:
Jacks serve no purpose when not in use and provide additional pathways for rodents.
x3 - colliehaulerExplorer III
beemerphile1 wrote:
X-2
Jacks serve no purpose when not in use and provide additional pathways for rodents. - beemerphile1ExplorerJacks serve no purpose when not in use and provide additional pathways for rodents.
- Dutch_12078Explorer IIIOur motorhome doesn't know if it's parked for storage or on a campsite, so the jacks are always down.
- blownstang01Explorer
downtheroad wrote:
Motor home or trailer?
31' Winnebago class C - downtheroadExplorerMotor home or trailer?
- Chum_leeExplorerUnless the manufacturer specifies otherwise, the common way to "park" hydraulic systems is with the pressure as neutral as possible. Think about it. Are you going to put a brick/stick on the brake pedal to lock up/apply the hydraulic brakes too? (air brakes and cable operated parking brakes are different) IMO, it really doesn't matter much, just your preference for your particular situation.
If you leave the MH parked with the hydraulic jacks down and they won't retract when you plan to move it, (for whatever reason) you'll be waiting where you are until you can get the jacks to retract.
Chum lee - SoundGuyExplorer
blownstang01 wrote:
I store my RV under a carport with a concrete slab. Should I store it over the winter with the jacks down, taking most the weight off the tires, or no ?
If you're using the trailer as a man cave while it's parked at home then sure, level it and drop the stabs, otherwise there's no point to it. - Dick_BExplorerJust slightly off topic but I think you should put plywood under the tires to keep them off the concrete.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
