Chum_lee
Oct 20, 2018Explorer
Unless the manufacturer specifies otherwise, the common way to "park" hydraulic systems is with the pressure as neutral as possible. Think about it. Are you going to put a brick/stick on the brake pedal to lock up/apply the hydraulic brakes too? (air brakes and cable operated parking brakes are different) IMO, it really doesn't matter much, just your preference for your particular situation.
If you leave the MH parked with the hydraulic jacks down and they won't retract when you plan to move it, (for whatever reason) you'll be waiting where you are until you can get the jacks to retract.
Chum lee
Chum lee
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
