We Cant Wait wrote:
All CAT scales (at truck stops, and CAT guarenties their weigh) I've seen are level with the ground, so if you watch driving on you can put 1 side of the coach off the scale and 1 side on, this will give you weights per axle on the one side, then reweigh the coach fully on the scale and just subtract the one side weigh to get the other sides weight.
Yes this is a good theory, but you will not be able get repeatable numbers, so your going to be guessing. A platform scale is design for a vehicle to drive on with the vehicle in a 'drive on'position not straddling off to one side. This is why they build curbs, or install poles so you drive on like it was built for. Finding separate scales is the best way to get 4 wheel weighs.
