presidio40 wrote:
Just got 6 new Michelin XZA2 Energy tires and based on the chart I should have 90 psi in the rear and 110 in the front.
Sounds about right, but without knowing what size tires there is no way to know if 100/90 is correct. Most of us go 5 psi over what the chart calls for.
Good thing you are coming from a boat so maybe you will not need to go on a diet in a year when your re-weigh. You may need to loose 10 lbs to make up for the 10 lbs for the tongue weight from the tow bar.:B Yes, you could tow a heavier toad.
