presidio40 wrote:
So GVW is 31680 and GVWR is 32000
I guess we are just below limits. My question is, can we tow our 2600Lbs car if the GCWR is 42000.
Also being close to the limit is a real problem or can we live with it as this is as heavy as we will ever be with all tanks full.
Thanks
GVW is below 32000 pounds (Max GVW is 32000 so you are good there)
If you add 2600 Pounds of car you will be at 32280 pounds which is well below your 42000 pound Max CGVW so you are still good.
DO make sure the car has an aux brake system,, Invisi Brake,, US-Gear, M&G, Air force one.. One of the INSTALLED systems with a break-away cable.. Avoid the all-in-one box in the driver's seat systems.
